Clears a previously configured software-controlled redundant port.
| port_list | This refers to the primary port of the redundant pair and specifies one or more ports or slots and ports. |
N/A.
The list of port numbers or the port display string specifies the primary port(s).
The following command unconfigures a software-controlled redundant port on a switch:
unconfigure ports 3 redundant
This command was available in ExtremeXOS 11.1.
